Pete4
How to transmit a modulated signal continuously for compliance testing?
I need to know how to write some code to simply transmit a continuous modulated signal for compliance testing.
Travis Palmer
Travis PalmerBest answer
Hi PDiet,
for simply turning on the field it is sufficient to execute the startup procedure. (including Regulator adjustment and AAT)-
Afterwards you can enable the carrier by turning on the "en" and "tx_en" bit.
BR Travis
Travis Palmer
Hi PDiet,
BR Travis
