CShac
How to Read the TID memory from an RFID tag
Has anyone implemented their own firm ware. I can so far successfully retrieve the EPC number from a tag, however I'm struggling to get a valid RN16 and CRC combination when using the REQ_RN command. I would like to do this to be able to access the TID memory.
CShac
CShacBest answer
Yes I have managed to do this.
Bart Herse
Hello Chris,
it seems you have solved the problem already?
Cheers,
B
CShac
CShacAuthorBest answer
