How to hand-make a ~15 cm loop antenna for STEVAL-25R200SA? Again
Hi again,
Since the new version of ST Community I can't find my previous post, so I'm creating a new topic to follow up on the old one. The replies from @AScha.3 and @Brian TIDAL on that thread helped me a lot before it disappeared.
As I mentioned, I'm a beginner in this field. The full context is in my earlier post:
I have just one more question. You mentioned that building an external antenna is easy, but is it really doable for a beginner? I'd like to know whether I can realistically do it myself if I buy the right equipment to measure inductance, or whether I need an expert to guide me.
Also, in addition to AN6065, I found AN2866, which is more readable in my opinion and provides a step-by-step procedure. I don't understand everything yet, but I'll work through it.
Thanks!
Berenice BENVEGUDA
previous answer by Brian Tidal :
Hi, Informations about antenna design for ST25R200 can be found in Application Note AN6065 Antenna design for ST25R200 and ST25R100 devices. Rgds BT
Andrew Neil
See:
MelioNBAuthor
I wasn't aware that the topics between May 22nd and June 9th hadn't been migrated. I'll wait.
Thank you!
Berenice BENVEGUDA
