TDrez.1
How to connect multiple ST25R3916 readers to the java sdk
I'm needing to get readings from more than one st25r3916 at once for a project using the pc (and java sdk). I'm unsure as to how to do this because
"STReader stReader = new STReader(); stReader.connect();"
Always connects to the same reader - the only sucess i've had so far is by running 2 instances of the program which isn't fit for purpose.
Can anybody help?
Thomas
    Damien G.Best answer
    Hello Thomas,
    the ST25 Java SDK can manage several tags but only one reader at a given time, as you discovered.
    Unless you disable the COM port of the first reader before connecting to another reader, you will always find the same device first.
    Regards,
    Damien
    Hello Thomas,
    Regards,
    Damien
    Hi all.
    I have same needs of OP, using many ST25R3911B readers connected to same Windows PC host and connecting a given instance a of custom Java application to a given reader.
    Are there any news about this feature with latest ST25SDK releases?
    Thank you in advance.
    PT
