DSai.1
how to change antenna driver output register for ST25R3916
Dear Sirs,
We use ST25R3916 for our reader and  want to adjust  output power (0x28).
We use RFAL library, could you tell me how to change the antenna driver output register (0x28)
with the RFAL library, which function or variable should be used for the adjustment?
best regards
Dai Sai
Ulysses HERNIOSUS
Hi Dai Sai,
sorry for the late answer, your question seems to have slipped through.
In RFAL there is a function named rfalChipSetRFO() for doing this.
BR, Ulysses
Ulysses HERNIOSUS
Hi Dai Sai,
BR, Ulysses
DSai.1
DSai.1Author
Dear Ulysses,
thank you very much for your information.
I found the initial value setting is 0. We will use the
function, if we modify the value.
best regards
Dai Sai.
