angad
Hi, I would like to program the st25r3911b-disco board and use it to read ISO-14333A tags. It would be great if someone could point me to relevant online resources for the same. Thank you
    Ulysses HERNIOSUS
    Hi Angad,
    The software for ST25R3911B-DISCO is available as STSW-ST25R002. But:
    1. It only supports Keil toolchain
    2. It is mainly a proxy to be controlled by PC application.
    I recommend you to use XNUCLEO-NFC05A1 + XCUBE-NFC5 instead. It comes with a system workbench project and also has all logic implemented in firmware.
    Regards, Ulysses
    Ulysses HERNIOSUS
    Open up the ST25R3911-DISCO GUI. This GUI will allow you to read/write T2T. The ST25TagEditor therein will allow you to read/write T4T.
    If this not what you actually want to do then you need to provide some more information:
    • Which exact tags? Manufacturer, model?
    • You want to do this from our GUI, from your PC application, from an embedded program, ....?
    Regards, Ulysses
    angad
    angadAuthor
    I wanted to know if we can write code for the ST25R3911B-DISCO board using something like system workbench. If yes, then How?
    Best,
    Angad
    Ulysses HERNIOSUS
    Hi Angad,
    Regards, Ulysses
