PMK.1
Help for designing matching circuit for CR95HF
CR95HF-VMD5T I'm using this part number for our design can you please help out to design antenna tuning circuit for flexible antenna
flexible antenna electrical parameters which has going to use
Inductance-1.40 uH
Frequency-13.56 MHz
    Brian TIDAL
    Brian TIDALBest answer
    Hi
    Application Note AN5248 (ST25R95 transceiver antenna tuning circuit with EMI filter) provides information about the design of the matching circuit for ST25R95/CR95HF devices
    The ST25R95/CR95HF EMI filter calculation tool STSW-ST25R003 helps  to calculate and adjust the antenna tuning circuit.
    Rgds
    BT
    Brian TIDAL
    Hi
    Rgds
    BT
