Grounding the center of the NFC antenna loop
Hello!
Can you tell me the reasons and meaning of the necessity of grounding the center of the ST25R3916 antenna loop?
In X-NUCLEO-NFC08A1 the jumper between the center of the antenna loop and ground is closed, but in ST25R3916 Discovery Board it is open.
Best regards, Rob.
Ulysses HERNIOSUS
Hi Rob,
topic has been discussed here: st25r3916-gnd-on-antenna.
I think this should answer your question.
BR, Ulysses
Ulysses HERNIOSUS
Hi Rob,
BR, Ulysses
Rob_TalorAuthor
Thank you!
