atlas
Gerber File for ANT7-T-ST25DV04K
Hallo, i Cant find any gerber file for the ​ANT7-T-ST25DV04K.
Or can someone tell me what thickness and spacing the antenna has.
Many thanks
Denis ROMAN
Denis ROMANBest answer
atlas
atlasAuthor
Thanks ROMAN.
RGeorge
The internal capacitance tuning of m24lr is 27.5pf and that of st25dv is 28.5pf, does that make a difference in the case of antenna here?
Denis ROMAN
​Hello,
internal capacitance is the same in practice. So you can use same antenna for both chips.
Have a nice day
Denis
LHell.1
I'm looking for this as well, but the link above is now 404.
TMalt
Same here, also looking for the gerber. And in addition the eDesignSuite NFC antenna calculator wont let me calculate a 14 mm antenna.....
Danm I need it!
