Raphael_Ko
Failed to change EPC number of an NXP SL3S1203_1213 tag
I have to change the EPC number of a NXP SL3S1203_1213 UCODE G2iL tag (https://www.nxp.com/docs/en/data-sheet/SL3S1203_1213.pdf). Unfortunately, this does not work on the NXP tag. I suspect that I have to do an unlock etc. before I write, but I can't figure it out. Does somebody has any idea?
Cedric Dalban
Cedric DalbanBest answer
Hello Raphael,
sorry for the late reply.
That is a good point you moved to the latest version, this would have been my first suggestion.
This 2.1.0 version contains bug fixes, performance improvements (up to 800 tags/sec)
and most of all a consolidated API lib (aka STUHFL) allowing to operate as a Host library providing
an easy to use interface to communicate to ST25RU3993 Reader IC based development boards.
best regards,
Cedric.
Raphael_Ko
With the new ST25RU3993 STUHFL SDK package v2-1-0-0 it works fine, first try was with v1-8-6. Thanks!
Cedric Dalban
Hello Raphael,
best regards,
Cedric.
