Brian TIDAL
Brian TIDALBest answer
Hi Ted,
Thermal Pad must be grounded for ST25R3916/16B/17/17B/18/19/19B/20/20B.
Rgds
BT
Brian TIDAL
which pin number/pin name do you refer to?
Rgds
BT
TedAAuthor
Hi Brian,
Thanks for the quick response.   The pin number is 33, which is named Thermal Pad.  It is a 3.5mm x 3.5mm square pad on the bottom surface of the chip.
Ted
Brian TIDAL
Hi Ted,
Rgds
BT
TedAAuthor
Thanks so much, Brian.
