RAvkh
Example code for X-NUCLEO-NFC06A1
I want to use ST25R3916 in our bank card NFC reader.
There can i find example code for X-NUCLEO-NFC06A1, that implements Tag detection, Anticollision, SELECT, RATS, APDU...?
    Ulysses HERNIOSUS
    the https://www.st.com/en/embedded-software/x-cube-nfc6.html is the support package for the the X-NUCLEO-NFC06A1.
    As you mention banking cards, if you actually target EMVCo compliance ST does also have an explicit demo board for EMVCo (similar to https://www.st.com/en/evaluation-tools/st25r3911b-emvco.html).
    Regards, Ulysses
    Ulysses HERNIOSUS
    Regards, Ulysses
    RAvkh
    RAvkhAuthor
    Hello! Thank you for the answer!
    Where can i find complete ref. design with CAD files for https://www.st.com/en/evaluation-tools/st25r3911b-emvco.html?
    Ulysses HERNIOSUS
    for getting the support package you will need to go through your local ST support team.
    BR, Ulysses
