per
Jul 1, 2013 10:10 AM UTC
EMI problems with DEMO-CR95HF
Posted on July 01, 2013 at 12:10
Hej!
I just bought a DEMO-CR95HF board to sort out EMI problems that I have with my own design with the CR95HF chip. To my disappointment the DEMO board generates more harmonics than my own design. My measurements can be found at
http://milvus.nothagen.se/pub/strfid/rfid.htm
Also, when I checked the resonance frequency of the antenna I found that it was tuned to 15.2MHz and not 13.56. The resonance frequency was measured using a spectrum analyser with tracking output.
Therefore I wonder:
Is DEMO-CR95HF designed for optimal performance?
Is there any known optimization can can be done to the board to improve performance?
I was planning to use the layout for the circuit between the chip and the antenna. As a consequence of my measurement above I really wonder if you would recommend that? I have also looked at the layout of PLUG-CR95HF-B which is slightly different. Is that layout better?
Best Regards
Per Nothagen
Senior Engineering Manager
Triacon AB
#cr95hf #emi-filter #demo-cr95hf-a #plug-cr95hf #cr95hf
Anais GALLIGANI
Anais GALLIGANIBest answer
Aug 29, 2014 3:38 PM UTC
Posted on August 29, 2014 at 17:38
Hello ,
For such kind of question, please get close to your ST sales or use Online support tool.
Thanks a lot for your comprehension,
Have a nice day,
ST NFC RFID Dynamic tag support
Anais GALLIGANI
Jul 15, 2013 1:51 PM UTC
Posted on July 15, 2013 at 15:51
Dear customer,
Might you send us your email address please?
Thanks a lot,
Have a nice day,
All the best,
NFC/RFID dynamic tag support
byronl
May 30, 2014 1:35 PM UTC
Posted on May 30, 2014 at 15:35
Hi Nothagen,
Did you ever resolve your harmonic issues? I am battling with the same issue and any advice you can give would be appreciated
Best Regards
Byron Loader
Anais GALLIGANI
Hello ,
Have a nice day,
