Driver for ST25R3912 with external microcontroller.
- 1 reply
- 1634 views
Hi ST support team,
We use ST25R3912 with solution for design phone (use chip microcontrller SM6150(Qualcomm)),
We have problem need you support list in below:
1: If we design without MCU_CLK signal, do we can use Transparent mode for AFE and framing implemented in the external microcontroller?
2: Can you support about the driver can implement all your NFC requirements (NFC card emulation, NFC reader/writer, NFC peer-to-peer) if you use SPI bus only (internal framing in NFC chip).
Thanks,
AnhDN
