gaby_bradu2
CR95HF Write Tag sequence (Error - 0x87 EFrameWaitTOut)
Posted on October 29, 2015 at 13:21
I use CR95HF to read/write data to M24LR64E.
I get error 0x87 when I try to write more blocks.
Th efollowing sequence:
< Write Block 1 (0x0A 0x21 block1 data)
> Status ok (0x00 0x78 0xF0 0x00)
- delay (it does not metter how big, 50, 100, 500, 1000ms)
< Write block 2 (0x0A 0x21 block2 data)
> Error CR95HF (0x87 00)
The same problem I get when switching between write & read even if I have enough delay between.
 - read data - ok
- read data - ok
- delay (1000ms)
- write data - ok
- delay (1000ms)
- read dada - error
- read data - error
- read data - ok
What happends?
Thanks in advance
    Nickname6430_O
    Posted on November 13, 2015 at 11:30
    can you please provide me some information about your protocol select? Are data written in the memory after error? To be able to read again after error do you have to do new inventory or do you have to reset tag by turning off power?
    Petr
