magicstreber
Nov 24, 2013 5:19 PM UTC
CR95HF Write command
Posted on November 24, 2013 at 18:19
I use
the CR95HF
chip
for
reading and
writing data
in the
NFC
forumtag
Type 2
Tag
NTAG203F
I can
read the
data,
but
can not write data to Tag,
although
NTAG203F
is writable
When I
send
a command to
write
data
, the response
I get from
the
CR95HF is
0x90
0x50
0x80
0x01
0x22
0x00
0x00
In
dataseet
for
CR95HF(Doc ID 018669 Rev 2) I
can not understand
what does mean
Result
code
0x90
? Please, could you explain me response from CR95HF.
Best regards,
Nenad
#cr95hf
Anais GALLIGANI
Anais GALLIGANIBest answer
Nov 30, 2013 7:37 PM UTC
Posted on November 30, 2013 at 20:37
  • When the tag responds correctly :
    the response has CR95HF header 0x80
  • when it is incorrect (wrong CRC, insufficient data received),
    ->generated the header 0x90 and the packet  format is equal to 0x80 (0x90, len, data, status+collision report )
The report 0x90 is reserved for ACK or NAK
I hope this is helping you,
ST NFC/RFID dynamic support
Posted: Sunday, November 24, 2013 6:19 PM
Subject: CR95HF Write command
I use
the CR95HF
chip
for
reading and
writing data
in the
NFC
forumtag
Type 2
Tag
NTAG203F).
I can
read the
data,
but
although
NTAG203F
is writable
When I
send
a command to
write
data
, the response
I get from
the
CR95HF is
0x90
0x50
0x80
0x01
0x22
0x00
0x00
In
dataseet
for
can not understand
what does mean
Result
code
0x90
Best regards,
Nenad
Anais GALLIGANI
I use
the CR95HF
chip
for
reading and
writing data
in the
NFC
forumtag
Type 2
Tag
NTAG203F).
I can
read the
data,
but
although
NTAG203F
is writable
When I
send
a command to
write
data
, the response
I get from
the
CR95HF is
0x90
0x50
0x80
0x01
0x22
0x00
0x00
In
dataseet
for
can not understand
what does mean
Result
code
0x90
Best regards,
Nenad
