Hvu m.1
CR95HF read tag ISO14443A response 0x87 0x01 0x90
i'm read data into block 0 but response 0x87.
anybody help me fix it, thanks you so much.
I don't know where is wrong?.
[drv95HF_ReceiveSPIResponse]Response: 55 00 00 00
[drv95HF_SendSPICommand]Send comand: 02 07 02 00 00 00 00 02 02
[drv95HF_ReceiveSPIResponse]Response: 00 00
[drv95HF_SendSPICommand]Send comand: 09 04 3A 00 5A 04
[drv95HF_SendSPICommand]Send comand: 09 04 68 01 01 DF
[drv95HF_SendSPICommand]Send comand: 04 02 26 07
[drv95HF_ReceiveSPIResponse]Response: 80 05 04 00 28 00 00
[drv95HF_SendSPICommand]Send comand: 04 03 93 20 08
[drv95HF_ReceiveSPIResponse]Response: 80 08 5E 17 82 5B 90 28 00 00
[drv95HF_SendSPICommand]Send comand: 04 08 93 70 5E 17 82 5B 90 28
[drv95HF_ReceiveSPIResponse]Response: 80 06 08 B6 DD 08 00 00
[drv95HF_SendSPICommand]Send comand: 02 07 02 00 04 01 00 03 03
[drv95HF_SendSPICommand]Send comand: 04 03 30 00 28
[drv95HF_ReceiveSPIResponse]Response: 87 01 90
    Ulysses HERNIOSUS
    you seem not be aware of UIDF1. So likely the card is not personalized that way. Also reading block 1 will not work without cryptography and mutual authentication using crypto1.
    ST does not provide code for supporting MifareClassic cryptography.
    Please also see https://community.st.com/s/question/0D53W000014zGpESAU/st25r95-data-read-and-write-problem-iso1443a
    Best Regards, Ulysses
    Brian TIDAL
    can you provide some information about the tag being used (manufacturer and model)?
    0x87 means timeout. Possible causes:
    • tag takes too long to respond to the 0x30 00 READ command (i.e Frame Waiting Time on reader side is too short)
    • tag does not support the read command.
    Note: the protocolSelect command you used ("02 07 02 00 04 01 00 03 03" ) has ST reserved bytes (in bold). I would recommend not to use those reserved bytes
    Rgds
    BT
    Hvu m.1
    Hvu m.1Author
    thanks for reply
    i use lib provice by ST
    lib_iso14443Apcd.c
    lib_iso14443Apcd.h
    • the tag support read command, sure
    i will remove reserved bytes and try again
    Brian TIDAL
    I guess you are using a Mifare classic tag. For your information, reading block 0 after cascade level 1 anti-collision in such tags is only possible for UIDF1 personnalization. This was my rational for asking more information about the tag (model/manufacturer/personalization). Feel free also to share details about your hardware setup: do you use a custom board or a ST board (X-NUCLEO-NFC03A1 or M1054B transceiver board) or other ST board?
    Regarding the library, for new projects we recommend to use our RFAL which provides a common API for the various ST25R readers (see ST25 embedded NFC library).
    Rgds
    BT
    Hvu m.1
    Hvu m.1Author
    0693W00000WI42FQAT.jpg0693W00000WI42KQAT.jpgyes, i have use mifare classic and this board connect to STM32F103C6T6
    because flash capacity of stm32f10c6t6 is small so i need more optimized library
    after i remove remove reserved bytes the result is as follows (read block 1)
    [drv95HF_SendSPICommand]Send comand: 02 05 02 00 00 00 00
    [drv95HF_SendSPICommand]Send comand: 02 05 02 00 04 21 00
    [drv95HF_SendSPICommand]Send comand: 04 03 30 01 28
    [drv95HF_ReceiveSPIResponse]Response: 90 04 04 24 00 00
    Ulysses HERNIOSUS
    Hvu m.1
    Hvu m.1Author
    i see. but i don't see any way to send MifareClassic cryptography.
    I'm having a hard time finding documentation to solve this problem
    thanks for reply
    Brian TIDAL
    In your trace:
    "[drv95HF_SendSPICommand]Send comand: 04 03 30 01 28
    [drv95HF_ReceiveSPIResponse]Response: 90 04 04 24 00 00"
    90 04 04 24 00 00 means a 4-bits ACK/NAK reply has been received from the tag. This is a NAK reply (value 4h: invalid operation). This is caused by trying to read the block #1 whereas the mutual authentication has not been performed as explained by Ulysses.
    I would recommend to use ST25TN tags that support READ command without specific proprietary authentication/cryptography.
    Rgds
    BT
    Hvu m.1
    Hvu m.1Author
    i used ST25TN card but i need to integrate different cards
    thanks for reply
