Aug 9, 2026 6:41 AM UTC
CR95HF DLL compatibility issue?
Hi everyone,
I’m currently working with the CR95HF evaluation kit and looking into using the provided DLL (CR95HF.dll) for PC-side communication for a legacy project
However, the DLL seems to be compatible with 32-bit systems and I am looking for the 64-bit compatible version. As clarified in other discussions, the DLL needs to be recompiled for x64 compatibility. (CR95HF DLL x64 compatibility – is a 64-bit version available? | Community)
So my questions are:
  • Is there now an official x64-compatible version of the CR95HF DLL available?
  • Or is the recommended approach still to request/use the source code and rebuild the DLL for x64 systems?
Regards,
Aman
Brian TIDAL
Brian TIDALBest answer
Aug 10, 2026 4:49 PM UTC
Hi Aman,
M24LR-DISCOVERY evaluation kit which includes the CR95HF transceiver board is Not Recommanded for New Design (NRND). The ST25R95/CR95HF is NRND too. See ST25R100/ST25R200 readers and STEVAL-25R200 evaluation kit for replacement.
The CR95HF.dll is an x32 DLL. In case you need to rebuild it for 64-bit systems, the source code can be provided to you.
Rgds
BT
Brian TIDAL
Hi Aman,
Rgds
BT
Aug 14, 2026 5:29 PM UTC
Hi Brian,
Thank you for your quick response. I am working on a legacy project that was setup on a 32-bit environment and I need to port it to a 64-bit version.
If you can help me source code as you mentioned, it would be really helpful.
Thank you,
Aman
Brian TIDAL
Aug 18, 2026 7:10 PM UTC
Code source sent in PM
