mossaab daiki
control reader command
Posted on June 29, 2018 at 12:55
Hello, Can I configure ST25 reader to send only 13.56 MHz carrier ? if So how to do that?
    Ulysses HERNIOSUS
    Posted on July 10, 2018 at 14:28
    please have a look into the DS (
    https://www.st.com/resource/en/datasheet/st25r3911b.pdf
     :( Search for 'en' 'I_osc', etc.
    Transparent mode has 0xdc, no 16 bits!
    Regards, Ulysses
    Ulysses HERNIOSUS
    Posted on July 03, 2018 at 08:21
    Hi Mossaab,
    You just need to enable the Oscillator (en bit in register op control), wait for I_osc, and then set tx_en => constant wave.
    Regards, Ulysses
    mossaab daiki
    Posted on July 03, 2018 at 09:40
    Hi Ulysses,
    thanks for the reply do you recommend a specifi ST25 reader ?
    regards
    Mossaab
    Ulysses HERNIOSUS
    Posted on July 09, 2018 at 10:24
    Hi Mossaab,
    to date there is only one chip available on the boards in the web shop: ST25R3911B. You can either get it as ST25R311B-DISCO with a PC software or as a nucleo shield: X-NUCLEO_NFC05A1.
    ST25R3912 .. ST25R3915 are compatible variants.
    For your own developments the nucleo shield might be more suited.
    Regards, Ulysses
    Ulysses HERNIOSUS
    Regards, Ulysses
