Patrick1
Aug 1, 2018 8:15 AM UTC
Communication Error during tutorial (F401RE, NFC04A1 board)
Hi, I'm new with STM32 MCU.
While i was following the tutorial in USER MANUAL, i faced communication error and i don't know why.
I installed USB Driver, so here the USB PORT is fine with COM7.
However, usb software can't detect my BOARD. here is the capture
anyone knows how can i solve this??
USER MANUAL: https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/59/22/f4/26/87/f6/47/bd/DM00403798/files/DM00403798.pdf/jcr:content/translations/en.DM00403798.pdf
MY Window Version is 10
Thanks, Patrick
    NFC/RFID Customer support
    Aug 22, 2018 8:39 AM UTC
    Hi Patrick,
    I don't know why the exe cannot connect to the board.
    This is the process to succeed (I just reproduce it and it woks fine) :
    • Install ST Link Virtual port COM driver
    • Connect your NUCLEO-F401RE board to your PC (USB port)
    • Check Device is wll conncted (as you did seems ok)
    • NODE_F401RE (virtual disk) appears in Computer Disks list
    • Download X-CUBE-NFC04A firmware and UnZip it
    Now, you need to Upload a specific firmware to be able to manage USB connection and drive ST25DV-I2C tags through I2C bus in your NUCLEO board :
    • Open X-CUBE-NFC04A package
    • Go to : STM32CubeExpansion_NFC4_V1.2.0/Projects/Multi/Examples/Serial-USB_PCSoftware/Binary/
    • Choose STM32F401RE-Nucleo.bin file, then Drag and Drop it to NODE-F401RA virtual disk
    Leds are blinding to indicate that the firmware is loading
    Now you should start X-NUCLEO-NFC_software.exe software and be able to detect the board.
    I hope this will help,
    Best regards
    NFC/RFID Customer Support
    Aug 8, 2018 3:59 PM UTC
    Not that it can't find the COM port, it is that whatever software you have loaded on the NUCLEO board is NOT responding.
    For shields connecting to the VCP check the SB (Solder Bridges), some of the SB6x ones as I recall. Review User Manual
    Hi Patrick,
    Best regards
