Code Example for ST25R3916
Hello, I’m working on a project with an X-NUCLEO-NFC08A1 board to use it as an NFC Reader. Specifically, I have an NFC TAG, and I want to use the NFC08A1 board to read and write to this TAG.
I’m currently looking for some example code to help me use the NFC08A1 board as a reader.
Do you have any code suggestions or any links where I can find reference examples for this?
Many thanks in advance!!
Best Regards
Brian TIDAL
Brian TIDALBest answer
Hi Stefano,
you will find some ready to use demos inside the X-CUBE-NFC6 package. It can be used with the STM32CubeMX tool to generate the demos for a given STM32 MCU and contains also already generated demos for some nucleo boards.
Rgds
Brian TIDAL
Hi Stefano,
Rgds
