Cannot open file CR95HF.lib while including CR95HF DLL
I am trying to use the "CR95HF.dll" file provided in STSW-95HF002 to make my own Visual C++ application. I tried everything I can to load this DLL but the visual studio is not able to lead it and gives a linking error - LKN1104 Cannot open file 'CR95HF.lib'
I googled this error and tried all the possible ways and still was not able to proceed.
I want to make a console application of my own to read my tag from MB1054B board.
What is the configuration required by the Visual Studio so that I can avoid this error? Should the configuration platform on Visual Studio project should be x64 or Win32? What should be the build configuration, build or release?
Also, I tried putting the .lib and .dll file at the same location as the my project's solution file. It should work right? the .dll file is also placed at C:\Windows\System32
I want to make a .exe where the terminal pops up and starts reading my tag and printing the data.
Some help on this would be appreciated :)
best
KenadamsBest answer
No worries, I solved it. It was a target selection and Visual Studio config issues. :)
KenadamsAuthorBest answer
