BDe S
May 10, 2019 6:54 AM UTC
Can we access X-Nucleo-NFC05A1 from ARM Mbed ?
First of all I am very new to application development with ST-Electronic device shields.
I have following devices with me,
X-NUCLEO-NFC05A1 - NFC expansion shield
Nucleo 64 : F401RE board.
I was doing some samples with ARM Mbed online compiler.
I want to access external NFC tag's content via NFC05A1 expansion board in ARM Mbed. However, I was not able to find a correct library for NFC05A1 expansion board in ARM Mbed. But, I found a sample and a library for different version of NFC shield : https://os.mbed.com/components/X-NUCLEO-NFC01A1/ and this is not compatible with the NFC05A1.
I was wondering whether there is a library which I can use in ARM Mbed to access NFC functionality in X-NUCLEO-NFC05A1 board.
Note: I found a following CUBE sample for this expansion board but, I do not think this can be used in ARM Mbed as a library.
https://www.st.com/content/st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-nfc5.html
    Ulysses HERNIOSUS
    May 21, 2019 10:51 AM UTC
    unfortunately we don't provide an mbed version. However the X-CUBE-NFC5 contains the so-called RFAL (RF Abstraction Layer) which is written with portability in mind.
    BR, Ulysses
    Ulysses HERNIOSUS
    BR, Ulysses
