YKim.2417
Dec 10, 2019 12:07 PM UTC
Can l use the x nuclio nfc05a1 as a shield for the stm32 nuclio 144? Can you send me a ex source code for the arduino ide.
    Brian TIDAL
    Brian TIDALBest answer
    Dec 11, 2019 12:54 PM UTC
    an Arduino support is provided for X-NUCLEO-NFC03A1 ST25R95/CR95HF reader (see https://github.com/stm32duino/X-NUCLEO-NFC03A1). As far as I know, X-NUCLEO-NFC05A1 is not supported in Arduino environment. X-CUBE-NFC5 provides support for IAR Embedded Workbench for ARM, Keil Microcontroller Development Kit (MDK-ARM), and System Workbench for STM32 (SW4STM32).
    Rgds
    BT
    Brian TIDAL
    Dec 10, 2019 4:26 PM UTC
    The ST Zio connector of the STM32 Nucleo-144 boards extends the Arduino™ Uno V3 connectivity, As explain in the STM32 Nucleo-144 boards User Manual (UM1974) §6.14, . most shields designed for Arduino Uno V3 can fit to the STM32 Nucleo-144 board. See §6.14 for details about hardware configuration of Nucleo-144 for the proper support of such shields.
    See also "Having trouble with X-Nucleo-NFC03A1 and Nucleo-F413ZH" for similar question for support of X-NUCLEO-NFC03A1 with NUCLEO-F413ZH STM32 Nucleo-144 development board.
    Make sure to make the proper pin assignment configuration. I would recommend to use STM32CubeMX for the pin assignment and the pin configuration.
    For example with NUCLEO-F413ZH:
    PA5 -- SPI1-SCLK
    PA6 -- SPI1_MISO
    PA7 -- SPI1_MOSI
    PD14 -- SPI1_CS
    PA3 -- IRQ_3911
    PC0 -- LED_F
    PC3 -- LED_B
    PC1 -- LED_A
    PF13 -- LED_FIELD
    PE11 -- LED_V
    PF14 -- LED_AP2P
    Rgds
    BT
    waclawek.jan
    Dec 10, 2019 5:12 PM UTC
    Hi Brian,​ @Brian TIDAL_O​
    the OP probably expects that once the pinout is Arduino-ish, he/she would be able to program the board in the Arduino environment.
    Is there such option?
    @YKim.2417​ please change your username to a normal nick.
    Brian TIDAL
    Rgds
    BT
