Jakob K.
Jan 6, 2018 12:24 AM UTC
X-CUBE-SPN7, 6Step_Lib.c
Posted on January 06, 2018 at 01:24
Three questions regarding MC_SixStep_Ramp_Motor_calc()
1.) What unit do the mechanical acceleration rate parameters/variables have? (apparently not 1/min/s or rad/s²)
2.) 'mech_accel_hz = SIXSTEP_parameters.ACCEL * Rotor_poles_pairs / 60' - so 'mech_accel_hz' is rather the electrical acceleration than mechanical?
3.) I found that MCM_Sqrt() takes 1,3 .. 1,8 ms (32 MHz CCLK) while the (ARM-MDK) math library's sqrt() takes 150 .. 250µs. What is the benefit of using
MCM_Sqrt()
Thanks for comments.
