Saltr.1
Nov 16, 2021 2:12 PM UTC
Where I can find a code example to run a Qi TX using the STWBC2-HP IC?
I bought a STWBC2-HP and I designed a board as specified in the datasheet, but I can't find any support for the firmware part. Do you have any block code to integrate to a custom firmware to drive the mosfet and implement the WPC protocol?
