Aanil.1
Nov 10, 2020 12:54 PM UTC
what is the suitable buck converter that could convert 55volts to 5volts 10amps
i need a dc-dc step down power supply where the input varies from 45-55volts and required output of 5volts and 10amps
Patrizia BELLITTO
Dec 1, 2020 9:26 AM UTC
you can use eDesignSuite to easily select and design your power supply converter.
Insert your specifications and the suitable ICs will be shown.
Best regards,
Patrizia
