Prajnyajit
May 31, 2021 4:28 AM UTC
What are the peak input power and current limit for SPV1050?
I'm using a 694W solar cell whose Voc is 6V, Vload = 5.03V at MPP (Maximum Power Point). Its Isc and ILoad are 160mA and 138 mA at MPP. Under this condition, is it safe to use SPV1050?
Peter BENSCH
May 31, 2021 9:08 AM UTC
You probably made a mistake and mean 694mW, right?
Regarding SPV1050: as you can read in the data sheet, the maximum battery charging current is given as 70mA and therefore doesn't fit in your application.
/Peter
Prajnyajit
May 31, 2021 9:18 AM UTC
​Hi, Peter! Thank you so much for your answer.
​I'm using a 0.6W solar cell whose specifications are as below
Voc = 6.2V
​Vload (Max) = 5.02V
​Isc = 147mA
Iload (Max) = 138mA
I am using a 1000 mAh lithium-ion cell as storage. Please let me know should if I can use SPV1040 instead of SPV1050?
Peter BENSCH
May 31, 2021 11:37 AM UTC
The SPV1040 should be able to handle this, but please read the data sheet carefully as table 4 lists some precautions, e.g. for output voltages above 4.8V:
According to the absolute maximum ratings the output charge voltage cannot be above 4.8 V but if a higher VOUT up to
5.2 V is needed, a Schottky diode must be placed between the Lx and VOUT pins as shown in Figure 1. In such way the
Schottky diode in parallel to the embedded P-channel MOSFET reduces the voltage drop between the VLX pin and the
VOUT pin determined by the body diode when the internal PMOS is OFF from 0.7 V down to 0.3 V.
/Peter
