Jul 9, 2026 2:35 AM UTC
VNS3NV04DPTR-E
The test conditions of VINCL parameters of VNS3V04DPTR-E chip are: Does light inject 1mA current into the IN pin, and does the SOURCE pin need to be grounded?
Peter BENSCH
Peter BENSCHBest answer
Jul 9, 2026 6:24 AM UTC
Welcome ​@7589545, to the community!
The test parameters for VINCL specified in table 6 of the VNS3V04DPTR-E datasheet refer to the protection diode at VIN. In this case, a current of 1 mA, or a reverse current of -1 mA, is applied, with the respective source pin serving as the opposite terminal.
In this respect, I can answer your questions with yes and yes.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
7589545Author
Jul 10, 2026 3:15 AM UTC
Thank you for your answer. I also want to ask, when testing this test item, do other pins of the chip have to be suspended?
Peter BENSCH
Jul 27, 2026 11:54 AM UTC
I only have the test circuits from the datasheet as well, but I assume that when testing the input diode, only the relevant input and source pins are used, and the other pins remain open.
/Peter
