TH3221
Jun 9, 2024 3:26 PM UTC
VNF9Q20F Grounding
From the application schematics of VNF9Q20F, seperating my ground planes for CReg and DVcc but wouldnt DEV_GND (straight from the VNF9Q20F at the bottom) be connected as well instead of to battery ground? Shown as the drawn orange connection. Or both?
AScha.3
AScha.3Best answer
Jun 10, 2024 9:14 PM UTC
What you expect ? New physics ? Something working without solid gnd level , as good as possible ?
AScha.3
Jun 9, 2024 4:12 PM UTC
Because from ds :
you should connect pin17 to ground plane , same as the cpu. And to (car) gnd(chassis) of course.
Separating ground plane is no good idea, except for low noise analog circuits. (you dont have here - right?)
TH3221
TH3221Author
Jun 10, 2024 7:35 PM UTC
Your right no low noise analog circuits, unless I would assume this chip would have something like that built in like for the current sense maybe? I just am trying to figure out why they would have separate grounds in the application schematic then?
You can see GND and DEV_GND? I've read the datasheet over and over and didn't see a reference to it
AScha.3
AScha.3Best answer
