Feb 11, 2025 4:35 AM UTC
[vnf1048f] K Value
I'm using the vnf1048f chipset.
k value is required for current sensing, but it is not specified in the data sheet.
Can you tell me what the k value is?
Peter BENSCH
Feb 11, 2025 8:49 AM UTC
Welcome @gj_it, to the community!
The VNF1048F is not a high-side switch, but a high-side switch controller, where there is no K factor in the sense. Instead, measurements are taken via a shunt and the voltage dropping there is measured with a 10-bit ADC in a voltage range of 0...160mV (data sheet, section 3 and table 13 or table 45).
Does it answer your question?
/Peter
