Sep 9, 2025 6:09 AM UTC
VND5T016ASP-E High Side Driver IC Hardware Design
Hello everyone,
I would like to use the VND5T016ASP-E high-side driver in my design.
For one board, I need to use 12 of these ICs.
I have reviewed the application note; in your opinion, which configuration should I use for this IC to have fewer EMC issues?
Also, would it be a problem if I share the FR_stby pins among these 12 ICs?
Thank you.
