Jan 31, 2024 11:54 AM UTC
VN920D-B5 chip
Hello
Since the VN920D-B5 chip is not available, I am looking for a replacement. I am looking for another system with similar parameters.
Please help me.
Peter BENSCH
Peter BENSCHBest answer
Feb 1, 2024 7:32 PM UTC
First of all, it must be mentioned here that the VN920D-B5 as well as the VN920-B5 has long been obsolete and the VN920B5TR-E is already on NRND.
However, as you have already discovered yourself: the STATUS pin on the discontinued VN920D-B5 was digital, while the CURRENT SENSE pin on the VN920B5TR-E (and the discontinued VN920-B5) is analogue, which is why one cannot replace the other without hardware and software changes.
Ah, and in case you're wondering what you can replace the VN920D-B5 with: I'm really sorry but I'm not aware of any alternative device.
Does it answer your question?
/Peter
Elena BRAMBILLA
Jan 31, 2024 4:36 PM UTC
Hello Pietia
If you mean VN920B5-E    SINGLE CHANNEL HIGH SIDE SOLID STATE RELAY
the product is available.
 https://www.st.com/en/automotive-analog-and-power/vn920b5-e.html
regards.
Elena
pietiaAuthor
Feb 1, 2024 8:35 AM UTC
VN920D-B5 - pin status digital
VN920-B5 - pin sense analog
Can I use VN920 instead of VN920D?
Peter BENSCH
/Peter
pietiaAuthor
Apr 18, 2024 1:06 PM UTC
Thanks for the answers.
