Frank Ambrosius
Jan 31, 2017 1:03 PM UTC
vn750ps-e input absolute maximum
Posted on January 31, 2017 at 14:03
Can anyone tell me what the maximum voltage is on the input pin (not Vcc) of this part?
Thank you in advance.
Regards,
Frank
Oliver Beirne
Jan 31, 2017 8:26 PM UTC
Posted on January 31, 2017 at 21:26
Hi Frank
Could you take a look at the Forums menu at the top of this page and let me know which option applies to your questions please? I can then move this question to the appropriate forum where someone can help you.
waclawek.jan
Jan 31, 2017 10:24 PM UTC
Posted on January 31, 2017 at 23:24
Frank,
Look at the input clamp voltage.
Oliver,
This is an automotive switch. I'd put it into Power Management etc.
Wouldn't it be easier if the Forums would match the product tree on the main ST page?
Oliver Beirne
Feb 1, 2017 3:48 PM UTC
Posted on February 01, 2017 at 15:48
Hi Jan, thanks I'll move it there. The forum structure was determined internally prior to launch so will likely not change too much in the near future. However we are reviewing forums all the time and if a change needs to be made then we will do so.
