Peter BENSCH
Peter BENSCHBest answer
Aug 31, 2026 8:58 AM UTC
The VN02H was originally still produced in the PENTAWATT package, which was discontinued without replacement many years ago. So there is no direct pin-to-pin replacement.
However, you could check whether, for example, an IPS1025H-32 or IPS1025HQ-32 with an adapter board could be used instead, which would of course bring challenges for the thermal design.
Good luck!
/Peter
Peter BENSCH
Good luck!
/Peter
Aug 31, 2026 9:15 AM UTC
ok thank you very much
