daniele_stefani
Sep 22, 2011 3:08 PM UTC
Viper53 24V-1A full range
Posted on September 22, 2011 at 17:08
Hi I have one new project for my application and I have used the Viper53-E (dip8) to build a small SMPS AC/DC. After the selection of components with the VIPER SOFTWARE, I have build the SMPS, but don't have the correct voltage in output.
In the attached file the electric drawing and the data of transformer.
In the out I have 50V not
I have reduced the secondary winding at 10 turn, but the output voltage don't change why?
Best Regards
Daniele
Jakub HAJEK
Sep 23, 2011 10:15 AM UTC
Posted on September 23, 2011 at 12:15
Hi Daniele,
You can try to use the secondary regulation and I would consider the switching frequency. I think, the 300kHz is not optimal. The 100kHz would be more suitable.
Best regards
Jakub
daniele_stefani
Sep 23, 2011 11:53 AM UTC
Posted on September 23, 2011 at 13:53
Thanks Jakub,
I have verified the switching frequency this morning and is 100kHz.
I
further modified
the number
of turns
of the secondary
from 22 to
8 turns
to lower
the output voltage
and
now I'm
changing the
transformer turns
ratios
to further improve
the operation
Daniele
