Explorer II
Jul 11, 2025 9:31 AM UTC
VIPER31 switching losses
I would like to use the VIPER319HDTR and would like to check the thermal to see if Tj will be an acceptable value.
However, the switching losses of the internal FET are not mentioned. Is the switching time of the internal FET known? Or is there another way I can verify the thermals of the device?
Thank you in advance!
Kind regards,
Beau Wilmink
Peter BENSCH
Peter BENSCHBest answer
Jul 11, 2025 12:03 PM UTC
Self-heating is caused by several factors, which is why it seems to make the most sense to simulate the design. You can use the free online tool eDesignSuite for this purpose (select AC/DC > Start a new project), which also calculates and graphically displays the switching losses, among other things.
Hope that helps?
Good luck!
/Peter
Peter BENSCH
Hope that helps?
Good luck!
/Peter
