Jul 24, 2023 10:38 AM UTC
Viper26 power supply design
 anyone tells me how to design a 24vdc to 15vdc  buck converter using viper26ld?
Peter BENSCH
Peter BENSCHBest answer
Jul 24, 2023 1:29 PM UTC
If you want to stay with STMicroelectronics, there are a bunch of devices for converting 24V to 15V, the recommendation only depends on the output current. You could e.g. have a look at theL6981 or the L6986 .
Regards /Peter
AScha.3
Jul 24, 2023 11:43 AM UTC
hi,
you have 24V IN ? and want 15v out ? then viper26 is totally wrong for this.
take a LV2862XLVDDCR or TPS563300DRLR ; which current ??
Jul 24, 2023 1:18 PM UTC
   Thank you for your reply
  Current 400mA
Peter BENSCH
Regards /Peter
AScha.3
Jul 24, 2023 1:35 PM UTC
or cheaper and also STM : the good old MC34063 . ->
MC34063ABD-TR .
at mouser :  511-MC34063ABD-TR
Peter BENSCH
Jul 24, 2023 1:52 PM UTC
The MC34063 is a very old device working with very low switching frequency, which requires bulky passive devices. In addition it is an asynchronous regulator, which requires a Schottky diode. All in all this might be the more expensive and bigger solution.
