Dec 9, 2024 11:11 AM UTC
Viper01 or Viper0P startup voltage
Is it possible to start either of these Vipers up earlier than their stated HV startup voltage by sourcing VCC manually (external supply) from the Vin voltage?
Peter BENSCH
Dec 10, 2024 5:23 PM UTC
Yes, you can do that.
/Peter
thansenAuthor
Dec 11, 2024 10:16 AM UTC
Thanks for confirming that. This means I can also use the Viper0P which will greatly improve my standby/"off" current consumption.
I just need to know the behavior when Vin is first supplied. Will it start in ON or OFF (ZPM) mode ?
How does the Viper behave in a no-load situation?
