Oct 29, 2025 9:57 AM UTC
Unable to Find MOSFET
Hi, dear. Could you please help me find the datasheet for the MOSFET with part code GF329MB, as well as other compatible MOSFETs with similar specifications?
Thank you in advance for your help!
Peter BENSCH
Peter BENSCHBest answer
Oct 29, 2025 10:40 AM UTC
Welcome @manmohan, to the community!
This is (or was) the STP15810, which was discontinued in 2024.
As a replacement, you should be able to use the:
Hope that helps?
Good luck!
/Peter
Peter BENSCH
Hope that helps?
Good luck!
/Peter
