Chris118
May 9, 2025 9:05 AM UTC
TS4061AICT-1.25 marking
Hallo,
how do I know what marking TS4061AICT-1.25 has?
There is no hint in datasheet.
Can you help?
Peter BENSCH
Peter BENSCHBest answer
May 9, 2025 10:06 AM UTC
The markings of the devices are usually internal information and are rarely mentioned in the data sheet. However, the same markings can also be found on the box label.
/Peter
Peter BENSCH
/Peter
RobK1
May 9, 2025 10:26 AM UTC
I'm sorry Peter, but that does not make sense. In my experience, most datasheets actually do list the device markings. Just take a look at some of ST's own datasheets, like LM4040, TL431, TS821, etc.
Peter BENSCH
May 9, 2025 12:54 PM UTC
Unfortunately, you cannot generalise this observation: STMicroelectronics reserves the right to treat component markings as internal, non-official information. The different divisions treat this differently, so that sometimes you will find markings in the data sheet, but in other cases not.
/Peter
