May 6, 2026 11:39 AM UTC
Top marking LD59015C33R
Hello ST Team,
could you please provide the marking code for LD59015C33R?
Where can i find it on my own? A register to verify parts by codes would be great.
Thilo Roth
Peter BENSCH
Peter BENSCHBest answer
May 6, 2026 1:55 PM UTC
Welcome @Dillo, to the community!
The marking code is internal information, which is why it is not published - but the code is always also on the sticker on the packaging bag. Please note that all variants of the LD59015 are marked as NRND and may be discontinued at any time.
I hope to make you happy if I list the marking codes here:
  • LD59015C12R: 592
  • LD59015C15R: 593
  • LD59015C18R: 594
  • LD59015C25R: 595
  • LD59015C30R: 597
  • LD59015C33R: 596
Attention: the markings for LD59015C33R and LD59015C30R were not confused here.
Hope that helps?
/Peter
Peter BENSCH
  • LD59015C12R: 592
  • LD59015C15R: 593
  • LD59015C18R: 594
  • LD59015C25R: 595
  • LD59015C30R: 597
  • LD59015C33R: 596
Hope that helps?
/Peter
DilloAuthor
May 8, 2026 10:06 AM UTC
Thank you Peter, that's all i needed. Unfortunatly we don't get to see the package bag. We mostly purchase a smalller amount of parts. The suppliers don't provide the marking information.
Thilo
