Nov 1, 2023 12:14 PM UTC
Thermal Characteristic of LDO
The thermal characteristics of the LDL112PU33R show the junction to ambient thermal resistance (JA) and the junction to case thermal resistance (JC). However, the junction to board thermal resistance (JB) is missing. We need this characteristic for thermal simulation of the component on a board. Can anyone provide it or provide the necessary resources?
Thanks.
Peter BENSCH
Peter BENSCHBest answer
Nov 1, 2023 3:09 PM UTC
Welcome @royS7, to the community!
Rthjc is the thermal resistance from the chip to the board. For DFN and PPAK, this refers to the metal underside (slug), for SO8 to the pins. Rthjc is usually sufficient for thermal simulation.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
royS7Author
Nov 1, 2023 3:23 PM UTC
Could we consider Theta(JC) = Theta(JB) in this case?
Peter BENSCH
Nov 1, 2023 3:52 PM UTC
Yes, in your case you can set Theta(JC) = Theta(JB).
Good luck!
/Peter
