rolf
Jan 16, 2004 5:13 AM UTC
SW for PID-regulator in C-language?
Posted on January 16, 2004 at 06:13
rolf
rolfAuthor
May 17, 2011 8:16 AM UTC
Posted on May 17, 2011 at 10:16
We have to do a regulation loop for an universal motor within a ST7. The motor is driven controlled by a PWM signal and for feedback we have a tacho signal.
Does anybody already have developed a PID-regulation SW (or something similar) in C-language which could be shared with us?
Thanks a lot!
Rolf
n_muthukumaran
Rolf
i heard u have implement the discrite version PID can send the coding to my email id:it will helpful for me..
gaetano
Hi Rolf,
I have a draft of PI control routine write in C language but unfortunately the documentation regarding this routine is not yet available.
I think it's better to wait for a full debug soft before to send this one to you.
So at the beginning of next year, it could be possible for me to release this routine.
If, in the meanwhile, I found another routine already tested and functioning I will let you know.
Regards,
Tanio
n_muthukumaran
[hi gforte
I have an idea about to implement PI controller closed loop regulation. I need the assembly code to implement.i hope it will use to implement the PID controller please send it to my address
mailto:n_muthukumaran@yahoo.com
n_muthukumaran
Rolf
n_muthukumaran
Rolf
bille.stello
here is a PI(D) code:
s16 PID_Regulator(s16 hReference, s16 hPresentFeedback, PID_Struct_t *PID_Struct)
  s32 wError, wProportional_Term,wIntegral_Term, houtput_32;
  s64 dwAux;
#ifdef DIFFERENTIAL_TERM_ENABLED
  s32 wDifferential_Term;
#endif
  // error computation
  wError= (s32)(hReference - hPresentFeedback);
  // Proportional term computation
  wProportional_Term = PID_Struct->hKp_Gain * wError;
  // Integral term computation
  if (PID_Struct->hKi_Gain == 0)
    PID_Struct->wIntegral = 0;
  else
    wIntegral_Term = PID_Struct->hKi_Gain * wError;
    dwAux = PID_Struct->wIntegral + (s64)(wIntegral_Term);
    if (dwAux > PID_Struct->wUpper_Limit_Integral)
      PID_Struct->wIntegral = PID_Struct->wUpper_Limit_Integral;
    else if (dwAux < PID_Struct->wLower_Limit_Integral)
            PID_Struct->wIntegral = PID_Struct->wLower_Limit_Integral;
          else
           PID_Struct->wIntegral = (s32)(dwAux);
  // Differential term computation
  s32 wtemp;
  wtemp = wError - PID_Struct->wPreviousError;
  wDifferential_Term = PID_Struct->hKd_Gain * wtemp;
  PID_Struct->wPreviousError = wError;    // store value
  houtput_32 = (wProportional_Term/PID_Struct->hKp_Divisor+
                PID_Struct->wIntegral/PID_Struct->hKi_Divisor +
                wDifferential_Term/PID_Struct->hKd_Divisor);
#else
                PID_Struct->wIntegral/PID_Struct->hKi_Divisor);
#endif
    if (houtput_32 >= PID_Struct->hUpper_Limit_Output)
      return(PID_Struct->hUpper_Limit_Output);
    else if (houtput_32 < PID_Struct->hLower_Limit_Output)
      return(PID_Struct->hLower_Limit_Output);
    else
        return((s16)(houtput_32));
}     with
typedef struct
  s16 hKp_Gain;
  u16 hKp_Divisor;
  s16 hKi_Gain;
  u16 hKi_Divisor;
  s16 hLower_Limit_Output;     //Lower Limit for Output limitation
  s16 hUpper_Limit_Output;     //Lower Limit for Output limitation
  s32 wLower_Limit_Integral;   //Lower Limit for Integral term limitation
  s32 wUpper_Limit_Integral;   //Lower Limit for Integral term limitation
  s32 wIntegral;
  // Actually used only if DIFFERENTIAL_TERM_ENABLED is enabled in
  //stm32f10x_MCconf.h
  s16 hKd_Gain;
  u16 hKd_Divisor;
  s32 wPreviousError;
} PID_Struct_t;
I let you find something smarter to avoid using 64 bit variable ;)
Ciao,
Billino
