Oct 9, 2024 12:40 PM UTC
Suitable capacitance values for COMPA and COMPB
Hello expert,
We are designing a circuit using STWLC38.
What happens if the capacitance value of C8~C11 in the figure below is increased to 47n?
Will it be a problem?
Regards,
Ryoma
willzhouBest answer
Oct 10, 2024 2:19 AM UTC
Hi Ryoma
Increasing the COM capacitor will affect the modulation of ASK;
bigger is not always better, as this is related to the system.
Additionally, the voltage AMR amplitude of STWLC38 VRECT has limitations.
If the ASK signal is too high, it can easily cause chip damage.
willzhouBest answer
Hi Ryoma
RyomaAuthor
Oct 10, 2024 1:41 PM UTC
Hi Willzhou,
Thank you for your help with another Thread.
In the following thread you suggest increasing the capacitance values of COMPA and COMPB, why is that?
STWLC38JRM does not output 5V at VOUT pin - STMicroelectronics Community
I understand that too large a capacitance values can be a problem, but is 0.047 uF too large for C8~C11?
Are these values very severe?
Regards,
Ryoma
Oct 11, 2024 11:46 PM UTC
Hi Ryoma
Cap large do not mean ask mod also large. it depends on the sytems.
Oct 17, 2024 12:29 PM UTC
Thank you so much for the information.
