Aug 6, 2025 3:39 PM UTC
STWLC38 will not report Ptx correctly
I am trying to follow the Getting started with the STEVAL-WLC38RX document for FOD tuning attached. I am using STEVAL-WBC86TX, powered from a bench top PSU,  and STEVAL-WLC38RX, connected to an electronic load. Both are connected to the STMGUI. Following section 9.4 on page 60 of the above mentioned document. I have set all BPP FOD values to 0.
When using the RX FOD tuning page, as per the document, the Prx value is being read correctly. However, the Ptx value is continuously reported as 1084. This value does not change despite and current draw increasing on the PSU.
Why is it that the Ptx value is not changing?
Kind regards,
Lewis
Didier HERROUIN
Didier HERROUINBest answer
Sep 2, 2025 3:07 PM UTC
It maybe due to a wrong registers address, as I can not reproduce this issue on my side.
We have provided you some support by email, have you been able to solve your issue ?
If not , please open a OLS ticket.
Regards,
Didier Herrouin
Didier HERROUIN
Regards,
Didier Herrouin
