plawat
plawatBest answer
Mar 6, 2024 3:09 PM UTC
it seems vout do not get 5V output voltage.
Understood.
What may be the reason for this. Any changes to be made in the register settings?
regards
Vivek
Jan 8, 2024 8:26 AM UTC
plawat
plawatAuthor
Jan 8, 2024 8:37 AM UTC
Hi, Thanks for the response. We need the firmware for this in C to be used with Nordic IC. Please provide if possible.
Jan 8, 2024 8:42 AM UTC
Dear Customer
Please find this link can be solve your issue?
https://www.st.com/en/embedded-software/stsw-wlc38fwepp.html
Jan 8, 2024 8:46 AM UTC
Dear Customer
It is simple I2C Read/Write for Nordic IC to control STWLC38,
if you need feature software support, please give your email and our local ST Marketing team will contract you.
plawat
plawatAuthor
Jan 8, 2024 8:48 AM UTC
the files are .memh
our mail id is director@slimiot.com
Jan 8, 2024 10:19 AM UTC
Mar 3, 2024 12:57 PM UTC
if external do not have pull up res, SCL/SDA/qi_nINT need pull up res to VDD.
Mar 5, 2024 3:24 AM UTC
In EVK the resistance is 100k. It is for enb pull down.
About insufficient power out , can you get some waveform on VRECT/VOUT pin, so we can have more detail information.
plawat
plawatAuthor
Mar 5, 2024 3:09 PM UTC
1. When the wireless charger is in place and the wireless charging coil is on top of it, the I2C is able to find the address of the IC, else it does not. Is that normal?
2. Please see the Chip info output and
3. The register reading of mode monitor, when the coil is charging in the attached file.
Please guide us on what is to be fixed to get the desired charging.
regards
Vivek
Mar 6, 2024 2:54 PM UTC
Hi
1.When the wireless charger is in place and the wireless charging coil is on top of it, RX is working, so i2c module is working. So it is normal.
2.From your info,
vrect = 0x0BE3 = 5732mV
vout = 0x0015 = 25mV
icur = 0x0021 = 41mA
tmeas = 0x013D = 47.5C
plawat
plawatAuthorBest answer
Understood.
regards
Vivek
