noscreen1
Dec 22, 2006 5:33 AM UTC
STVD7 errors to fix
Posted on December 22, 2006 at 06:33
STVD7 errors to fix
gaetano
May 17, 2011 8:13 AM UTC
Posted on May 17, 2011 at 10:13
Hi noscreen,
the error message you got depends from the C compiler you are using, for instance COSMIC, and not from the IDE STVD7.
It means that a C function you defined in a ''.c'' module does not have a correspondant function declaration (the so called 'prototype') somewhere written in the program code (tipically the latter stays in a ''.h'' header file).
I kindly suggest you to read further the C language manual normally given with the compiler tool (for Cosmic this is true), where a lot of examples often follow the definition of ANSI C statement.
Best regards,
Tanio
noscreen1
noscreen1Author
As i'm using the STDV7 compiler, I would like to know the meaning of the ''missing prototype'' error. thanks :)
