Dec 12, 2024 4:50 AM UTC
STSW-L99615C GUI zip file invalid
Hey ST community!
I am trying to download the GUI for the STEVAL-L99615C from this LINK
But when I try to unzip this folder I get an error saying that the file is invalid. Is this happening to anyone else?
Thanks for any help!
Peter BENSCH
Peter BENSCHBest answer
Dec 17, 2024 9:33 AM UTC
The problem with the incorrect file extension has been fixed, now the software from STSW-L99615C can be used as a regular ZIP file.
/Peter
Peter BENSCH
Dec 12, 2024 3:27 PM UTC
Welcome @eplamers, to the community!
Sorry for the confusion - it was accidentally saved as a ZIP file, but it is a 7z file. If you rename it to 7z, everything should be fine.
Hope that helps?
/Peter
eplamersAuthor
Dec 13, 2024 1:31 AM UTC
Peter,
Ahh perfect, a simple fix! That did the trick, thanks so much!
Peter BENSCH
/Peter
