AKINI.1
Jan 2, 2023 12:27 PM UTC
STSPIN32G4
Hello ,
We want to drive two independent hub motor ( as like hoverboard) with STSPIN32G4 . Product overview says "Finally, with an additional external three-phase driver (such as the STDRIVE101) two independent 3-phase BLDC motors can be efficiently driven from the STSPIN32G4, offering an unprecedented BOM saving and application optimization." but I couldnt find any document .
Do you have any advice about that
Thank you
Abdullah KINIK
SAHA Robotik
KnarfB
Jan 3, 2023 6:18 PM UTC
Have you seen EVSPIN32G4, EVALSTDRIVE101?
hth
KnarfB
cedric H
Jan 3, 2023 8:18 PM UTC
Dual drive is doable with the STSPIN32G4, but this solution is not yet supported by the X-CUBE-MCSDK . If you plan to use the ST firmware solution, the dual drive is planned to be back with the summer release 2023 expected begining of July.
Cedric
